lee160
Ive been installing Ring daylight running lights, map,boot and number plate leds.The last owner put bright white headlamp and fog bulbs but i need to do the side lights which look a bit of a pig to do.Ill be putting leds in those as well.I also changed the number plates and put the shaped rear plate on which looks great.Im looking at changing the head unit to an ipod unit.Now im not sure but it sounds like all the speakers are in the doors and theres nothing behind me.Theres no fader control so that must be the case.Does that mean ive got the standard set up?I read somewhere about fibre optic cables which i had on my Boxster so if you wanted to change anything you had to change everything!!!This forum is the best ive been on over the years for cars.As for the door cards ive got used to them now
Make sure you only use can bus LEDs!! If you don't the bulb out lamp on the dash will stay on.
