Old Oct 13, 2013 | 04:00 AM
dom03's Avatar
dom03
Default Re: So I hit the gutter, really hard! need help
Could someone please help me verify these are the correct part numbers?
Front Suspension:
1. Lower ball joint (excessive movement, require replacement) 05099237AA
2. Drag link (excessive movement, require replacement) 05098996AA
3. Steering damper (leaking) 05097971AA
4. Power steering lines/belts/filter/oil (belt frayed, requires replacement) 05097758AA
Front Brakes: Can anyone suggest some high performance aftermarket brake discs, pads, and rotors (complete brake system kit upgrade)
Front pads (nea rmin thickness, recommend replacement)
Front rotors (below min thickness, require replacement)
Rear Suspension:
Shocks (RH leaking, requires replacement) 05096751AA
Lateral arms - lower (Arms bent) 05143012AA
