oledoc2u
Well it's not nascar. It's a fact. A simple brake touching a rotor will cause this. My point is it isn't always alignment. Do this. Switch the front tires around. Move them to opposite sides. If it still pulls left it is not tire structure. Next make sure air pressure is equal on both sides. Change air to more if that doesn't work try less. Not all tires are equal. While switching tires around check for wheel bearing wobble on the left side. And there's more if none of this works.
Or as Oledoc says, it could be a dragging brekae pad. After you drive for a while stop and see if the rotor on the left side is hot.
Spray water on it, do not use your hands.
It is a lesson you won't forget but who, beside me of course, needs to learn it the hard way.
