Old Oct 15, 2013 | 04:55 PM
kylacke's Avatar
kylacke
Default Re: 2004 MT Will Not Roll Over
Thanks, Mrmiata!
When I disconnect the battery long enough, I do encounter the same issues. Two attempts to start, and then nothing until I disconnect the battery again.
I read another post from SuperStar where he disconnected the battery and the module, reconnected in the opposite order, and everything started working again. (Had also tried just disconnecting the battery, multiple times, to no avail) Considering I just replaced an old battery, I'm going to try the same to see if it might just need a reset.
On another note, I've called two different Chrysler dealers for a price on the SKREEM module (referred to it as the Sentry Key Remote Entry Module) and neither could pin down the exact module. Their closest guesses were the Control (Door Lock), which was roughly $200 (I assume this is not it, as the service manual shows it being located in the door), and the Module (Homelink), which was $405 (Which I also assume to be the wrong part, as I think this is just the homelink module in the roof of the car). Anyone have the exact part number, or know where I can find it? Not having any luck in the service manual.
Thanks again.
