Elena, those heater control valves are a regular fault, you've probably already been told this trick but the first thing is to give them a tap as they often stick and a few taps with a spanner will often free them without actually removing or undoing anything.
Hi Ken and PCT
Thanks I like the sound of cheap fixes, I will let you know if it's a success. But just to make sure I am hitting the right bit the valves are two silver cylinders close to each other and there isn't anything else that looks like them under the bonnet?
Kind regards
Elena
