Old Oct 19, 2013 | 09:38 AM
pct's Avatar
pct
Default Re: Heater blower resistor
Originally Posted by ElenaB
Hi
I did tap the valves but still no heat. The valves started to get hot but no heat from the vents. I think I tapped them hard enough, is there anything else I can try?
Regards
Elena
Nothing else that springs to mind, it sounds like the control valves are receiving hot coolant if they feel warm, but the hot coolant isn't getting from there to the heater matrix for some reason so either they are stuck closed or there is a fault elsewhere.
Hopefully someone else will come along with some ideas.
