Old Apr 4, 2006 | 03:01 PM
sohc808's Avatar
sohc808
Default Re: how to remove headlights!!!
You can remove the two upper retaining bolts, then open the access panel in the fender well and remove the two lower retaining bolts. Lift the headlamp from the fascia and disconnect the wire harness connectors. Hope this will help you.
