JesseJamessrt6
I am tired of the OEM unit spinning one tire in turns or if the pavement isn't exactly smooth. I need full power to both wheels when the throttle is pressed, that's why I want the wavetrac. From the look of your exploded diff, the wav trac is still good and doesn't change how long the ring and pinion last.
That makes perfect sense, as I love my Wavetrac.
amx1397
the higher the number (Crossfire from 307 to 327) the less hp and torque it takes to turn the wheel,,
example a 2003 PT Cruiser Turbo auto has a 3.91 gears,because the car is 3500lbs and the 4 cyl does not have much power so they went up in gearing.
Transaxle Final Drive Ratio 2008 PT Cruisers
Engine
Ratio
2.2L Turbo Diesel 3.29
2.4L (Automatic Transmission) Turbo 3.94
2.4L (Convertible) 2.70
2.4L std shift Turbo 3.29
Great info Jim.
+fireamx
This should prove to be worth the 10 year wait.
A CAI, and a propper gear is all the NA Crossfire ever needed to be competitive.
For the SRT's....it's just down right AWESOM!!
I like it so far, especially on the stree (0-60 MPH), but I'm not convinced the 1/4 mile will be much different.
oledoc2u
That gearing with the stick should really make an N/A come even more alive...add the wavetrac, and it is old school...
You've got me on that one, but I'm convinced the 3.27 is the best gearing for a street tire 0-60.
Billy22Bob
So is the general concensus around dragers - more gears = lower ET's?
I recall looking at some Dasdaq data and the 3>4 change was just before the 1/4 finished = another gear change.
At the time I questioned - given the ammount of torque we have for the weight - would it be better to go with a shorter diff....say 2.85-2.9
and if your target is 1/4 mile - 2 gear changes instead of 3.
Got me.
velociabstract
On a stock car that traps at 106 and the gear change happens just before or at the lights a 2.85 makes some sense (forgetting about the cost) but us modified guys trap 116 and higher. Were committed to 4th by over 10 mph so if I was to change the rear ratio which way would I go. Higher or lower? Depends on the goal and power level. I'd go lower. Hopefully I can leave it alone and never have to make a choice.
Les
Exactly
