Old Oct 20, 2013 | 03:38 PM
cossbreed82's Avatar
cossbreed82
Exclamation fan/rcm problem please help!
I have a 2004 na and i have had many malfunctions when the cooling fan detached from its motor causing my car to overheat. I towed it with the idea of repairing it myself with the help of this forum.I have replaced the fan and the 50 amp fuse under the hood. At first the new fan would run like it was in "turbo mode" very loud and fast. Then, my car temp was reading that it was overheating again and it shut off while I was driving. After about ten minutes, it started right up as if nothing was wrong. When i got it home, the cooling fan no longer worked until I disconnected the harnesses from the RCM. So I had the rcm soldered and replaced the crank positioning sensor as well, but the fan still will not run even if the a/c is engaged. By the way, the a/c stop blowing snowballs when the car overheated the first time. Have anyone experience this problem or has any idea on how i can fix it?
