Old Oct 23, 2013 | 09:07 AM
  #63 (permalink)
onehundred80
Default Re: Alarm going off on its own! Interior light flickers / unlocking randomly if drivi
Originally Posted by MMZ_TimeLord
Welp, here are my notes on the process.
I then laid down Black RTV sealant in the following shape around the hatch and let it set up for 20 minutes to skin properly. When placing the fiberglass in, line up your gap with the window edge above, start high and let it seat slowly. Then lift the hatch and match up your previous fastener washer marks for proper alignment of the panel.
Cheers!
I have just stumbled on this thread and have to respectfully disagree with the shape of the upper bead of RTV. The shape is convex and it should be concave so that water does not remain in a pool but runs out. The OEM seal was, when it was installed properly, a convex shape. The OEM seal separated from the sticky membrane and extruded itself out of the gap it was compressed in.
My later thread goes into this in more detail.
