Old Oct 23, 2013 | 10:57 AM
onehundred80
Default Re: Headlight problems
Originally Posted by JEFASOLD
That doesn't make sense since you say the highs are ok. Have they been correctly aimed? Both Hi and Lo move when the aiming screw is turned but I would set them using a grid and see what happens. It sounds like they may have become disconnected from the screw, there is a thread about the fix for that, you might find that the Hi's are actually low also.
He has put the bulbs in wrong, that is the usual cause of his problem.
