Old Oct 23, 2013 | 07:14 PM
  #65 (permalink)
onehundred80
Default Re: Alarm going off on its own! Interior light flickers / unlocking randomly if drivi
Originally Posted by MMZ_TimeLord
onehundred80,
If you will note, the convex shape is due to the shape of the actual fiberglass, NOT just the way it was drawn in the picture. You are welcome to TRY to make it concave, but it will not match the fiberglass to steel mating surfaces.
The seal was not on just a single face at the top, I studied all the pictures I could find on it and that was my conclusion. Some of the pictures show the adhesive tape on the original faces and the seal in a different place.
The OEM seal was/is a seal with a sticky backing and where the seal is on two faces the constant pressure moves the seal material off the adhesive backing into the area where there is less pressure IE. a bigger gap. This is similar to pinning an object to a wall with double sided tape, the object slowly creeps on the tape due to the weight.
In some cases the tape was applied in the wrong place at the factory.
It is a very awkward place to put an effective seal, putting a permanent seal is wrong I think, if anything goes wrong or the seal is not correct the first time the two pieces may be inseparable.
See my thread on the subject. CLICK
Also see JesseJamesSRT6's post with pics showing the path of the original seal and where the seal ended up causing leaks.
