Re: Covertible top won't go down
1. the divider switch in the trunk.
2. the top released switch just above the passenger's ear.
3. the trunk latched switch in the trunk latch assembly.
4. a blown fuse.
5. no fluid in the pump. ( check for leaks at all cylinders )
6. a bad pump.
7. a bad top up/down switch.
8. if the windows don't go down when the top lock is released ( with the ignition on ), then there is a bad switch in the windshield header at the right side latch position.
( what part of Georgia ? )
