Old Oct 29, 2013 | 10:51 PM
chrisificti0n's Avatar
chrisificti0n
Default Finally replacing wheels. 9.5" in rear
Chunks of metal missing from front passenger has prevented proper balancing and thus resulted in steering wheel vibration and whatnot for the past year.. finally getting new wheels.
The fronts are 18x8 +35mm and rears are 19x9.5 +35mm. Using stock size tires (had a spare set already laying around.. I think the front will stretch a bit but rear should be pretty acceptable for now, at least)
Offset calculator says the wheel would extend outward 6mm in the front. I think I can spare that.
The rear, on the other hand.. says I'll be tucked in an extra 7mm. Should I bother with spacers and long lugs on these?
