Old Oct 30, 2013 | 12:55 PM
MetalMilitiaSRT's Avatar
MetalMilitiaSRT
Default Re: Finally replacing wheels. 9.5" in rear
Originally Posted by crossfire1989
I am in the process of trying to get some Stern ST-5's to work. The offset on these wheels are +35 in the front and back. The rear wheel is a 9.5" I put them on and they looked great. However, a clicking or slight grinding sound comes from the back wheel when spinned on a lift. I had the garrage take the rear wheels off after not being able to figure out the sound. The tires had plenty of clearance. The wheel was not making contact with the calipers or anything. We came up with the idea that the bolts that the wheel dealer sent me are to long. We tried the stock lugs and it was worse. So good luck and any suggestions for me? Would spacers help? If so any idea what size? lol
STOCK REAR: AFTERMARKET REAR:
19x9" 19x9.5"
5x112 5x112
ET 22 (offset) +35
255/35/19
66.5
If it is the lug bolts... take the OE wheel off the car, insert one of the OE bolts into one of the holes, measure the length protruding out of the back. This number should be matched by the new bolts' protruding out of the new wheels. (±2mm)
