Old Oct 31, 2013 | 06:51 PM
onehundred80
Default Re: Windshield wiper issues
Originally Posted by BibaResto
Just whining. The impact driver on low removed the two nuts with no drama.
Now I'm stuck trying to unstick the wiper arm from the wiper unit. I'm surprised because when I was just pulling the arm back, it turned a bit - so figured I might have a too loose problem.
What composite is the center of the plastic arms? I'm thinking it might be a fairly hard rubber insert so that it expands once the nut is tight. Perhaps I'm old fashioned but hoped to see splines which would then just slip off. I squirted in some Kroil so letting it work a bit.
You can see the splines in the last part of the PDF under "Job Done" and in the second photo.
The part number for the Isolator is the Chrysler part number.
