Re: HELP-Buying SRT6-What problems to look for?
ala_xfire
if there IS water in the trunk, it's usually bad seals on the ironing board wing mounts.
Funnily enough the plugs in the bottom of the trunk are, wait for it ......... in the bottom of the trunk.
See picture of the drain holes in the picture in this thread.
Water also can ingress, new word of the day
, past the poorly designed seals on the spoiler mounting plate on the hatch.
Water also can enter through the rubber seals around the wires that enter the hatch at the top corners of the door.
Water can also enter but less often, around the gas filler door.
Leak in transmission, easy fix if it is the common leak.
Leaky steering damper, cheap fix for <$50.
