Old Nov 1, 2013 | 08:12 PM
jayswagger908's Avatar
jayswagger908
Default Re: Just got P0720 and P0600
Originally Posted by chaotictaco
Omg i'm about rdy to toss my crossfire in the river. In the last 4 months I've had issues with it. Just yesterday coming home from the gym. I'm at a stop light. Push on the gas and bam the car jerks hard. Car gets stuck in first gear and wont change at all. So i'm going 30 miles an hour with the rps hitting 4 grand mark. I pull over, turn it off same thing stays in first. check engine light comes on along with BAS and ABS. Get the codes p0500 and p0720. Ontop of that thats not the only issue I had. 2 months ago my car would shut off on me while driving. I'd get out and push it to the side. Try and start and it has juice but not enough to turn over. I get it jumped and turns right on, I drive and it shuts off again same thing won turn over. Well check engine light comes on. Come to find out my Crankshaft positioning sensor was bad and needed to be fixed which was only 50 bucks. I swear this car is becoming a total money sink.
the problem is your abs module you have 3 options to fix
1. replace at dealership around $1,900
2. order an new abs module on a mopar web site around $800
3. replace with a used abs module $ 250
I replaced with a used one and it works fine you can buy at a local junk yard or on ebay
