Old Nov 1, 2013 | 09:41 PM
tje275's Avatar
tje275
Exclamation Transmission Help Pleaseee!!!
My main question is will too much transmission fluid cause my shifting to be sluggish and sloppy? Some background information is that my car had a R&R done on the transmission about 45,000 miles ago, shifted fine until recently. First thing to start with is, I checked the fluid and it's like a yellowish color instead of a pink, so first thoughts are they put the wrong fluid and it's degrading or what not. Next I used a transmission dipstick and I/R gun to check the fluid level, at 130degrees it showed over 65mm, the chart says it's supposed to be at 42mm, and even when I checked it cold it was that high. Also apparently after reading every thread on here about transmissions and fluids, etc. I found out that the dipstick is supposed to go at least 28inches before it hits the bottom of the transmission tank but I can only get 25 or 26 inches before it touches, and I followed the manual and the threads on how to properly check the level, so I'm not sure what I'm doing wrong if anything. Any suggestions or advice would be greatly appreciated thanks, you guys have helped greatly in the past hope you can this time
