Old Nov 2, 2013 | 08:41 PM
pct's Avatar
pct
Default Re: Heater blower resistor
Originally Posted by ElenaB
Okay I now have heat, the valves were working fine. I had a blockage or air lock in the single hose coming from the valves. My friendly mechanic (one of my brothers best mates, very handy) fixed it for me, yeah. Now just the drivers heated seat to sort
Thanks for everyones advice, cheers
glad you got the heating sorted, failure of the heated seat (usually driver side) is another common problem, my drivers seat hasn't worked since I bought the car.
Assuming the light is coming on when you press the switch it is almost certainly the element in the seat itself, the wires break over time due to the repetitive flexing caused literally by repeated bums hitting the seat.
there is a repair kit available and if you search on here you'll find a 'how to' guide on doing the fix but its something I personally don't want to attempt on mine as it involves taking the seat apart and using knives and glue, and more importantly getting it all back together again looking right.
Here's the info if you fancy a go.
https://www.crossfireforum.org/forum/...structions.pdf
https://www.crossfireforum.org/forum/...kit-repair.pdf
