Re: Question Regarding 285/35/19 Tires
I used key words 285/35/19 and rubbing in my search. There might be (a) better term(s) but they're not coming to mind.
I've been running 285's Hankooks on stock wheels on my 04 Limited for years. I switched to the Mandrus a couple of years ago. As far as I can remember I never had an issue until I installed Koni shocks. After that the tires would touch the front of the wheel well when I jacked it up and I needed to jack the arm up to get the tire back on. Once it was back on the ground it was fine.
This past weekend I decided to swap the set-up (less koni's) with my 05 SRT6 for an upcoming trip. I like the feel of the Hankooks on the highway over the Pilots. Wouldn't you know, I have the same issue. It seems to more prevalent on the drivers side but that may only be because I installed the passenger side first.
Has anyone else experienced this? Does there seem to be a need for corrective action?
