Old Nov 4, 2013 | 05:15 PM
  #45 (permalink)
pjm30144's Avatar
pjm30144
Default Re: All my Aftermarket items for 50% off
If you like the "note" of the stock exhaust you will think the Magnaflow is too loud. It is nice at idle but at 2000RPM it's pretty loud in the cabin. I enjoy it that way but I am guessing you wont like it as it's much much louder than the stock setup. Also be advised that the doughnut gasket from the stock setup will not work with the magnaflow without leaking. You will need another different shaped doughnut to avoid the leak. My Muffler shop didnt have one that would work with the shape of the magnaflow flange so they put in an insert at the flange end with the correct shape on the end to seal with a new doughnut to the stock flange.
I bought my magnaflow from a forum member and he must have had this leak issue because there was a layer of permatex around the inside of the magnaflow pipe flange to seal with the doughnut.
