csteve0355
Did you go back and drop the muffler to add the rubber bumper - If so do you remember what size hole you drilled? Also the two rear plastic diffusers is this a must to gain access to the donuts?
I found removing the rear diffusers made it much easier, but you might get by without doing that.
I didn't have to drill a hole, I used the one in the body hanger.
I used a long wood bar to pry the muffler down to provide space, lubed up the nipple on the bumper with Vaseline and pulled it through the hole with needlenose pliers.
