Old Nov 9, 2013 | 01:34 PM
pjm30144's Avatar
pjm30144
Default Re: Changing oil questions
It will not change the mileage to next oil change.
To reset after you change your oil.
1. Move the ignition switch to the “RUN” position.
2. Within 4 seconds of moving the ignition switch into the
“RUN” position, press the reset button for the trip odometer
twice within one second. The display for the FSS service
request is activated for 10 seconds
3. During the 10 seconds the FSS service request is displayed,
move the ignition switch to the “OFF” position.
The FSS service request will continue to be displayed.
4. Press the reset button for the trip odometer and
hold
5. Move the ignition switch to the “RUN” position
6. Continue to press and hold the reset button for the trip
odometer (about 10 seconds) until the audible signal
sounds and the new start distance appears in the display.
The tool symbol should disappear at this time.
Hope that helps
