Thank you for the reply. No visible leaks. I just took the car out for a quick drive and it ran as normal with no gas smell.
Anything else I can try to diagnose?
onehundred80
Look under the car from behind the passenger side rear wheel, just behind the wheel is the fuel pump and filter. Look for leaks, there was a reported leak from a split hose in this area month or so ago.
If it is two separate problems then the engine may be running without the IC pump running when it gets hot. This would be obvious as the car will run OK until the car gets hot.
