Re: Stock Wheel Lug Bolts
rookie racer
I need 2 Stock size wheel studs [ missing 2 studs] Don't care if they are OEM or Afttermaket. Just need to fill the holes. What is the correct size and length for a Base Xfire with stock Rims?
Thanks !
Scott
E-Mail
sn1sn@horizonview.net
Well I guess you could take one out and measure it, as long as the car is available.
If not they are 12mm diameter and 39mm (nominal 40mm) under the ball seat to the end.
Length overall is 61mm.
