Old Nov 11, 2013 | 05:49 PM
cg80's Avatar
cg80
Default Re: Ignition Key Will not turn?? 2005 Coupe
Originally Posted by gguillot
If the key will physically not turn, then it is probably the sticky key issue. Try to get the key working by moving the steering wheel, especially if the wheels are turned far in one direction - move the wheel to take the "pressure" off the key lock. The sticky key fi is much easier if the key is still working.
gguillot: Had the same problem...$350 to fix...took a new switch from Germany installed by the local dealer. Carl
