Old Nov 16, 2013 | 09:43 AM
deeman13's Avatar
deeman13
Unhappy Re: Possible SKREEM module.. cont. from another thread
The failure could be due to one of many part failures. The SKREEM is just a single component of a very complex system.
OPERATION
The Sentry Key Remote Entry Module (SKREEM) has the following functions: receiving and evaluating the Radio Frequency (RF) keyless entry remote signal, actuation of door locks in conjunction with the Central Locking Pump/Security System Module, and enabling the vehicle theft security alarm with confirmation via the turn signals. When the RKE transmitter is operated, an RF signal is transmitted. If the SKREEM recognizes the RF signal as valid, it actuates the Central Locking Pump/Security System Module through the Body Control Module. The vehicle is then locked or unlocked through the power locks system. Connected to the SKREEM is a Sentry Key Antenna Ring which surrounds the ignition lock cylinder. When the ignition is switched on, the Sentry Key Antenna Ring is supplied with power. A data block is transmitted inductively via the Sentry Key Antenna Ring to the SKREEM and then on to the Powertrain Control Module. If the antenna ring data block content is invalid or if vehicle battery power is too low to build up enough power for the antenna ring, the Powertrain Control Module will not receive the proper signal. This is displayed with the message “Start Error” in the Instrument Cluster.
YIKES!!!!
I too replaced the casing on my key fob and then itaccidently fell on the floor and broke a part could this be the issue??
I too can take the battery cable off and it will start fortwo second and shut down X2 and then no crank at all. All your post are very helpful thanks
I am dealer bound and am not going to be happy to have change the SKREEM
