Old Nov 16, 2013 | 12:52 PM
BobbyCaz's Avatar
BobbyCaz
Default Need Help!!! Key wont turn
Yes i have read the articles on how to fix the sticky key. Wish those pictures were still available.....lol.
The key wont turn to remove the tumbler from the housing. tried over a thousand times. The steering Wheel is locked. I've tried to push in the pin, or at least what i think is the pin, to turn and remove housing. Won't budge. From what I've read. I'm screwed. I now need to drill out the pin, Yes?
The pin i am talking about, is the pin, just to the left of the collar that holds the housing in? Yes?
This silver pin. That i am assuming needs to be drilled out in order to completely remove the housing. Yes? And then i can replace the tumbler?
Does that pin need to go back in? or is the collart what holds it in place?
Just not sure if the pin i am describing is the rite pin. And does it need to go back in. Or is it garbage?
