Old Nov 16, 2013 | 02:05 PM
  #108 (permalink)
JesseJamessrt6's Avatar
JesseJamessrt6
Default Re: datalogs LEAN AFR
have some real logs from a couple 1/4 mile passes finally. Strange how the AFR starts rich and then by the end of the run leans out. I am also really surprised that with just a 62mm SC pulley I was showing up to 21 psi of boost. The last few logs the boost readings were really really low and not consistent so I am wondering if it failed. I also threw the P0108 over boost code on the last run.
Here is a log spinning most of the way down the track, I suck with street tires.
Here is the other log with more consistent TPS and RPM but the boost is readins are wrong
