Old Nov 20, 2013 | 08:34 PM
JEFASOLD's Avatar
JEFASOLD
Default Re: AFR adjustment via AFPR
Originally Posted by JesseJamessrt6
What regulator? Going to use the high flow fuel filter Mann Mercedes High Flow Fuel Filter
I have been doing a little research and I am not at all sure that we don't need the larger 550 injectors. The injectors should be working at not more than 85% duty cycle, so just adding the adjustable regulator and hi-flow filer, while it helps may not be enough. In the spring, I will try to get some datalogging in and see where I'm at but as I understand it, if the injectors are operating above 85% duty cycle for extended time they can fail. Rob, NW, fill us in here on this.
