Re: AFR adjustment via AFPR
How is your regulator set? Static pressure setting or adjustable through the inputs of boost and Zeitronix? nevermiond I see you are static at 60-62 psi
Silverarrow
Hi,
I'm running:
550cc injectors
Closed fuel rail
sL55 pump
High flow fuel filter
AEM fuel pressure regulator
Custom manis
90mm TB
61mm pulley
The fuel pressure stays constantly at 60-62PSI without any dipp Even at 6750rpm
And yes, the fuel pressure regulator was needed to achieve this.
/Adam
Reason: answered my own question
