Old Nov 21, 2013 | 12:28 PM
ImportLabSRT's Avatar
ImportLabSRT
Default Re: Bolt-on big brake upgrad from SLK55
I believe the fronts are a direct bolt-on and the rear are also, except they require a sleeve due to our smaller diameter bolts.
I drilled and tapped the rear spindles to accommodate the correct 12mm bolt.
