Old Nov 22, 2013 | 11:56 AM
32krazy!'s Avatar
32krazy!
Default Re: Crank Pulley Fell Off
did the outer ring come off or the entire pulley? did the elostomer between the hub and ring come out? slk32 crank pulley is about 250$ from oediscountparts.com . i have the crank pulley tool to hold it in place during torque sequence. torque is 147 ft/lbs PLUS 90* eat your wheaties
if the crank pulley hub came off the crank you most likely have a sheared keyway and possibly a damaged crank snout. pictures will tell us more
