Re: who wants a double din?
If I changed the radio I would want a double DIN with GPS so this looks good but has weaknesses.
If that plexiglass is just a butt joint, even if wire reinforced I would not give it much chance of a long life.
You need some kind of tenon joint or a doubler behind the joint.
What holds the bottom of the plexiglass, looks to me that it just flaps around. That alone will make the butt joint weak. From the screws down it looks springy.
Reason: doubler added
