Old Nov 24, 2013 | 09:30 PM
James1549
Default Re: Ignition Key Will not turn?? 2005 Coupe
Mark, I did the fix on my car but the key was not stuck and it was pretty easy. I would like to know in more detail, to help others, what exactly has to be done if the key won't turn. I know you must drill or cut the pin, but how did you do it?
James
Well, yea. I bought the Red Roadster in July of 2009 and knew about the fix after attending the fall Dragon in October 2009.
I never put the fix on that car, tho.
But this one locked up with NO WARNING a month after I bought it.
FIX IT NOW, even if you have NO SYMPTOMS, drilling the pin out due to a lock up makes the job way too tough!!!!
