Headlight Adjusting rotation switch
Hi all,
I have a little problem with the headlight adjusting in my crossfire.
I tried to aim the headlights a little higher using the switch. They were positioned on the lowest position, so pointed a bit towards the ground.
When i switch up 1 step, the headlights come up a bit higher. On the following steps ( i believe there's like 5 orso) the headlights don't move up at all.
Anyone got an idea where to look for a problem first? or did found a other thread with the similar problem because i could find it.
All advice will be much appreciated.
Greetings D&nis
