Old Dec 3, 2013 | 08:57 AM
oledoc2u
Default Re: What would cause this?
Originally Posted by lildaddym
Thanks for the tip...I will have to look around...car seems to run OK, and I don't hear any noises coming from under the hood.
You know if you do have fuel problems...running it out of gas does tend to heat up a fuel pump since the fuel is actually used to keep the pump cool. You may have damaged the pump...but right now, it sounds like it may be something simple. But I would keep that in the back of my mind if it doesn't iron itself out. I would change the fuel filter and the pump at that point. Good luck...
