Old Dec 5, 2013 | 12:41 PM
pjm30144's Avatar
pjm30144
Default Re: Changing ignition switch and lock cylinder
I agree and would do the sticky Ignition fix. If the little block that rides in the grooves in the ignition housing is worn or has a bur or the spring is weak etc that could cause these symptoms. When I did mine I replaced the housing with a new one that I did the mod on. I took the old one apart to see all the parts. No wonder it starts to stick. Poor design.
