Re: J.j.
The P0410 is pretty common and usually no cause for concern
probable fault areas are :
1. the relay contacts for the air pump in the relay module
2. a defective air pump
3. wiring problems
The P0335 usually means you need to order a Bosch CPS sensor and replace it.
