Old Dec 7, 2013 | 09:19 PM
grip grip's Avatar
grip grip
Default Re: Looped Fuel Rail?
Everything bolted right up. As for the FPSS, I connected it by adding an inline manifold, which in this case was just a female to male connector with a 1/8 or 1/4 NPT for attaching the FPSS.
Below is a pretty version of the manifold, as opposed to the ugly brass fitting I found locally.
Originally Posted by JesseJamessrt6
Did you send in your rail to have it modified or just afterwards as a core? Did the TTM passenger side looped connection bolt right up to your Zex FPSS or did you have to put in some off set connections to make it fit out at an angle like that?
There is info about fuel rail mods but not much about increasing the fuel supply line, any links or experience with this?
Fuel Rail DIY - MBWorld.org Forums
pics are missing from the first post.
MBWorld.org Forums - View Single Post - Looped Fuel Rail Questions???
Custom fuel rail milled from aluminum!
