Old Dec 8, 2013 | 02:52 PM
ala_xfire
Default Re: Idler Pulley (not tensioner) seized....why?
Easy. Remove the belt, remove the plastic cap over the idler bolt, remove the bolt holding the old bearing, install new bearing, install belt.
( the new bearing comes with the idler shell, you don't have to press out any bearings )
17mm socket for the boss on the tensioner to remove belt, T50 for the idler bolt ( use some LocTite on the bolt when reinstalling )
