Old Dec 10, 2013 | 12:00 PM
Tensung's Avatar
Tensung
Default Re: Sticky Key Revisited
Originally Posted by Mongoose57
Hi all, I to am thinking of doing this sticky lock thing to my 06 limited. But I neen to know
1) when the pin is removed I am assuming that the steering wheel can no longer be locked, therefor you can no longer have the car towed
2) does any one know why the pin sticks in the first place, is the pin at fault , the housing, or would taking it apart and lubing it up with graphite help
Thanks
Mongoose 57
Hi Mongoose, I had my Crossfire towed once by AMA (Alberta's version of AAA). They asked me what kind of car it was then sent a flat bed, like they would for an expensive sports car. Even if they hadn't, all tow trucks now place your wheels in a trolley rather than pulling them along the road. Nobody wants to be sued for messing up anything in your vehicle.
As for explanations as to what is happening with the pin and the most comprehensive instructions to remove or replace it you will ever see, look at the attached files and many thanks to rekcah
File Type: pdf
