Re: Crossfire, questions
First thing you should do is search here on checking the transmission fluid level. This is a symptom of low fluid level.
Also check the transmission connector for leaks.
At worst, you may have a bad conductor plate, there is also a DIY on that here on the forum.
Most likely not the TCM ( Transmission Control Module ), but one can never be sure.
