Osofast2
check the battery make sure it's not the original, usually this is caused by bad battery, and yes a bad battery will cause the symptoms
That is a good place to start. The car is very sensitive to having right amps to just about everything, or it will do strange things. Look under the floor cover on passenger side, as well in the trunk area for water. Moisture will also cause things to happen...good luck...
