Old Dec 12, 2013 | 03:49 AM
Kali_PL's Avatar
Kali_PL
Default Re: [2004 3.2 M112] Cylinder numeration
Originally Posted by sk8erjosh09
They go into the exhaust manifolds. Near the rear of the engine bay. The black plugs are right on the firewall I think (not sure, because mine are different).
Hi Guys,
I will give you an update on my issue, all I have done starting from point one:
1. I've replaced ignition coils on cylinders 1, 2 and 3.
2. I've deleted or the errors
3. Started up engine - it worked fine for about 5 miles, after that check engine started to blink again,
4. I've deleted or the errors again
5. I've disconnected the camshaft sensor on the left side of engine
6. Engine didn't started at all
7. I've connected the camshaft sensor
8. Car started and everything was fine for about 5 miles again
9. I've deleted or the errors again - still same errors as earlier
10. I've switched the 02 sensors
11. Car started and everything was fine for about 5 miles again
12. I've deleted or the errors again
13. Today in the these errors occurred:
P0134
P0135 - new one O2 Sensor Heater Circuit Malfunction (probably my fault )
P0154
P0300
P0301
P0302
P0303
P0304
P0305
P0306
I have no idea what can shall I do next, I assume that camshaft sensor is ok. I've didn't even touched the right side of engine, though above errors, right side of engine works normally.
Do You have any idea what shall I check next ?
Best Regards
Łukasz
