Old Dec 13, 2013 | 11:06 PM
Mongoose57's Avatar
Mongoose57
Default Re: Sticky Key Revisited
Thank to all for the help, my 06 limited key works fine but with all the warnings around this I will want to do it sooner rather than later. The sticky key fix PDF does not explain why it sticks in the first place. AMX 1397 says wrong!!! Do you mean even without the pin the steering wheel will still lock? Last tow I had a few months back ( Bronco II fuel pump ) truck did not bother to use wheel dollies and I will keep this in mind should I have the need to tow the Crossfire .
Cheers
Mongoose57
