Right door speaker problem
syfi, thanks for the info. Regarding the Infinity speakers, I assume you also used the tweeter. Does it just pull out from the door and is the new Infinity tweeter a direct fit? Or does the entire door panel need to be removed?
And where did you mount the crossover?
You didn't mention if you kept the head unit or not. If you switched it out, I'd like to know with what.
Biba
