Code may or may not pop up. Usually if it throws one it's stored for a period of time, even if the light is off.
Good luck and post back what this ends up being.
So after work I went to pep boys. They ran a code check P0335 crankshaft. They had one in stock and wanted 2 hours to install it. Reading on here people have said 10-20 minutes and 2 hours is almost $200 for labor and part. I said hell no. I bought the part only and went to my personal mechanic and he did it in 15 minutes for free.
I'll see if it stalls out any more or has trouble starting any more and keep you posted. Thanks again for the help. Much appreciated. Saved me a trip to the dealers and probably saved me around $400 figure a diagnoses from a dealer is $100 and the OEM part from them is $100 and the amount of time pep boys wanted would probably be the same at the dealers so another $200. So $400 from the dealers most likely and with you help I spent $50. Thanks again!
