Old Dec 19, 2013 | 01:16 PM
oledoc2u
Default Re: Valve Cover Gaskets + Oil Separator Reseal Repair Question from Newbie
His price is ridiculous. Unless his shop time rates is $200 an hour. Then he is spot on.... It's better to do it yourself. One reason being you can take your time to clean the vent cover up, and apply the RTV. I would let the RTV set up so it will form a good seal. Say 2-3 hrs, overnight if possible. Then put the covers back on. You may have some seepage around the oil filter housing which is from a poor seal when they replaced the filter. That you can take care next oil change. That is about all that leaks in the beginning. I am sure beyond 100K miles, the valve cover gaskets will need replaced as well.
Shop Hours: 1 hour... If in the Christmas spirit 1.5 Hours tops.
